Gator417
- September 4, 2013
- South West Mo
- 1995 Eddie Bauer
I rebuilt a 2wd 5r converted to 4wd 4r and just got it back in my truck. I used the case, bellhousing, VB, internals, and pump from the 5r and the externals, output shaft, nosecone and TC from the 4r.
My two issues are no reverse and no overdrive. The TC is locking up just fine, and the shifts are smooth and firm, both up & down.
I'm guessing overdrive just needs a band adjustment which I will get to in a couple of days, so no big disappointment there.
Reverse is very disappointing to me though. I noticed the reverse band was very loose in the case when I was assembling everything. I also dropped the tranny a couple of times from the jack when installing it. My best guess, as much as I hate to think about it, is that the reverse band has moved enough that it doesn't engage either the lugs or the servo or both.
Does this sound like it might be the issue? If so, is there a way it can be fixed without a complete teardown?
Thanks,
Gator
Thanks,
Gator
