elrynon
- January 30, 2009
- Winter Haven, Fl
- '00 Eddie Bauer 4.0 SOHC
Hey guys. Just got back from the shop with my ex. Had the engine rebuilt. Had the horrible timing chain rattle and cheapest place I could find to do the timing chain was $2500 and found a reputable shop to do a rebuild for $3500.
He did a complete tear down, New Pistons & Piston Rings, Re-manufactured Crankshaft, New Connecting Rod & Main Bearings, New Timing chain and Gears, New Oil Pump, New Complete Gasket Set, w/ New Front & Rear Crankshaft Seals, New Camshaft Bearings, New Brass Freeze Plugs, Valve job, with New Valve Seals, All Parts and Block are cleaned, Hot Tanked, Block Honed & Painted.
Now, I knew before hand that rebuilt engines aren't these whisper quiet "perfect" things until everything seats and he even mentioned when starting it that it would be a little noisy for about 200ish miles. Thing is though. This thing seems LOUD to me. I could just be paranoid but still. It's our only vehicle and I don't want to risk it. I took a video and put it up on youtube to see what you guys think. The sound has some echo to it and I was holding the phone right up to the engine because I wasn't sure how well the phone would pick up sound but you'll still get the idea. I'd really appreciate some input. Thanks everyone!
http://youtu.be/DM6BbOKRjh8
If you think I need to take a different video let me know and I'll do it asap.
