Ehtuttle00
- May 24, 2025
- Jacksonville, Florida
- 2000 explorer xls 4.0 OHV
I have a 2WD 2000 ford explorer XLS with the 4.0L OHV. I just replaced the camshaft position sensor due to engine code p0340. Since it’s been replaced (about a day now), no engine light has shown up. Car accelerates fine, but when coming to a stop and once stopped and idling, the idle drops from about 1000-1100 rpm’s to about 500 rpm’s and gets slightly shakey. Any idea on what could be causing this? The plenum was properly sealed and had its gaskets replaced, all hoses have been reconnected, all sensors have been reconnected and the harnesses/wires look good, spark plug wires have been put back on the coil pack in the right firing order, and I have no visible leaks and no noises (ticking, knocking, etc). The only other thing mechanically wrong is a power steering pump that is whining (replacing that soon).
