Put about a 120 miles on Red over the weekend over quite a bit of hilly terrain and high speeds highway driving. Everything seems good. However the P1405 code popped up, so I took a look at the DPFE and one the hose nipples had melted right off? So I need to replace that.
New synchronizer is in the works as well, the used one I pulled from a BC parts vehicle is squawking like a caged parrot. (New one was bad)
Also the front and rear driver door latches broke, so it is a pain to get in and out. Gotta order those.
Was doing some test drives and something on the passenger front wheel was clunking BAD. I went through the whole suspension, double checking bolts, adjusting the swaybar links and nothing fixed it. I was at the point of tightening the bearing bolts when I found the problem. The damn caliper bracket bolts were loose.
Kinda concerning since I was doing hard pulls up and down steep grades and hairpin turns.
I did however put in the new leaf springs and added the rear Bilstein shocks. Had to use different leaf pack hardware to swap in my add-a-leaf due to the hole being too small for the new leaf pack bolt, but he sits much better. Granted he still doesn't ride like a Cadillac, but it is an overall improvement.
I'm still getting used to the ticking sound from the headers, it sounds like an exhaust leak, but there isn't one. The BC guys tell me this is normal, so I'll just turn the radio up until I get a new cat back system (my old exhaust had so many leaks the sound drove me nuts, wasn't expecting it to become a permanent addition
Next time I'm up there (in 2 weeks) I'm getting the AC charged and an alignment, then he is coming home, dragging Stripe behind him.
