- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
Is there wear on the side of the rocker where the pushrod is near, or is just wear down in the Pushrod pocket? Can you tell if the pocket is any different in that worn one versus the other rockers? I'm wondering if that rocker had excess wear before and the pocket is worn and hurting the pushrod too.
What pushrods are those, stock, new/used, stock length, aftermarket, or hardened aftermarket? You should not need expensive hardened pushrods, those are for use with pushrod guide plates or very high rpm.
With that discovered wear, you need to look at all of them, both ends of all pushrods, check them for length and straightness. Give each a mild push down into the lifter, see if they all feel the same, should have some minor resistance but all the same. Look the rockers over carefully too, for any wear of those pockets or along the area where the pushrod or spring is near.
