Jhonny
- December 11, 2009
- Lynn,MA
- 04 EB
I'm trying to install a C3-RS-915LCD remote start on my 04 explorer with factory alarm
i can match some wires from the remote start to the explorer but some idk were they go or if they don't go at all, please let me know if i can forget about some wire and were the other ones go
Ground output while running- is the ground for a bypass
second starter output- N/A
2-step unlock/factory disarm/sensor by-pass - ?
Instant start and turn off input - FOR TESTING THE REMOTE START
dome light control output - NEED RELAY FOR THIS
Horn output(programmable) - SO IF I WANT TO USE THE FACTORY HORN
Channel 4 programmable output -NEED HELP IDK
Neutral safety switch input -IDK
Ground output when disarmed -IDK
Tachometer signal input -TO TACH WIRE
Channel 6 programmable output -IDK
Accessory 2 control output -IDK
Diesel wait to start input -N/A
Ignition 3 control output -N/A
Zone 3(-) negative dor pin trigger -IDK WHATS MY DOOR TYPE
Channel 2(trunk) output -IDK
Zone 2 negative hood/trunk trigger -TO HOOD PIN
(+)brake switch shutdown input -TO BRAKE SWITCH
Zone 3(+) positive dor pin trigger -IDK DOOR TYPE
(-) negative hood pin safety shutdown -TO DOOR PIN
Ground output when armed -TO RELAY
Channel 5 programmable output -IDK
were to mount the senser???
anyone knows if i can use the factory led on this?
the wires i know i got it from here http://www.commandocaralarms.com/wiring/2004-2005/Ford/Explorer/526.html so idk if they are right or not i try my hayness manual but can't find it
all you see on top is one harness from the remote start
the remote start has more with i know like the led light siren and more
thanks for the help
thanks for the help
