35Remmy
- March 4, 2008
- Binghamton NY, Hazleton PA, Northern NJ
- '88,'99 Ranger, '00 EX
OK, so I finally installed my Perma-Cool remote trans filter.
Brooklyn is right, the PRESSURE line is the one on the BOTTOM of the radiator.
On my '99 Ranger 4.0 OHV, that pressure line goes in to the trans cooler on the RIGHT side (as you are looking at the truck from the front).
I installed the filter at this line, before it enters the tranny cooler. Real easy since I didn't have to cut metal radiator lines, just rubber.
I mounted the filter inside the passenger's side fender well, on the plastic black "box" that sits around the radiator/trans cooler. I didn't trust mounting to plastic, so I went to Lowes and bought a metal double outlet box cover (flat, metal, 4" X 4", .65 cents). It was the perfect backing plate!!!
No change in shifting (some concerned about a pressure drop). Success!!!
