pax
- January 7, 2002
- Toronto, Ontario
- 95 XL 4x4 2door
I am having a hard time removing the upper bolt of the starter motor. I had the 13mm socket on the upper bolt, but the ratchet handle has no room to turn it. The front axle shaft and other stuffs are underneath blocking it.
Am I missing something here? How do you remove that upper bolt?
I searched this forum but all I can find is people saying just remove the two bolts. The bottom one is easy, but the top one, I don't know.
I don't see any way of turning the ratchet handle from the top or from the bottom.
I wanted to replace the starter before I get stranded on the road. Since the solenoid is acting up sometimes. It is about time, with 280,000km on the original starter motor.
