So the timing on the right cam is off . I just got the tools . gonna try it with tools .
I will remove tensioner , sprocket bolt . My question is will I be able to rotate cam into place once I get TDC on compression stroke .
if not any ideas ? I have vise grips , pipe wrenches etc.... Thanks Again
1= 135
2= 135
3=130 ish
I put a ballon on hose turned crank till ballon began to
inflate then I positioned it at 0 harmonic balancer
took the drivers valve cover off cause that side was in shade.
Mark I put on cam was perfect.
I'll try and do other side later or in morning
Covid is kicking ass here right now...
1= 135
2= 135
3=130 ish
