right turn signal buzzing | Ford Explorer Forums
Ray z
NJ
My right turn signal buzzes but doesn't blink. I did a search and see this is a common problem but no real answers. Has this been solved yet???? I hope so. any insight would be grateful.
Ray
Hi...I see you are a new member. Please try not to double post a new thread..... The question will be answered.. Just be patient
James, I apologize for my impatience, but this is driving me nuts.
Ray
well, buzzing with no blink, does it do the same with the left sig? I would check the bulbs first, then try changing the signal blinker (looks like a film canster) if you cant find it, I suggest getting a tech manual (Hayens) for your truck, will save you alot of time and money when it comes to simple problems
Mine was the left turn signal. I took the cover off and tightened the screws. Worked fine ever since.
LOL
LOL
Can you explain in more detail as to how to do this?
Sounds like the relay. It should be located in the fuse box...round thing about the size of a nickel. $3 part at Napa...
Jason_25 & Xtrackdog
What cover are you refering to. The front or rear light.
Ray
Mine did that a few years ago. The whole relay had to be replaced.
