My 1997 explorer sport just started making a buzzing sound.The left signals work fine with no buzzing.But the right does not work. All it does is make a constant buzzing noise?
This was about 10yrs ago, but IICR there was an issue with the steering column - crack it open and have a fiddle around with the junk that's under the cover...my tech ended up zip tying a few wires and maybe a control box of some sort to tighten it all up...
had the same problem with my turn signals last week and I was due for a new sticker so I had to cough up the money. Bought the new multi function switch at a cost of $102.00 here in Massachusetts. Got it home and took the cover off my steering column and removed the switch. Installed the new one and the problem was still there! Removed the new switch, put it back in the box and put the old one back in. Put the column back together and after doing some searching came to the conclusion that I didn't require a $102.00 switch from Ford. I needed a $16 relay from autozone!!!!
After looking at my receipt I also discovered that electrical items are not returnable or refundable! After som serious argueing I was able to get the dealership to refund the money but they said they can't give cash back. They have to mail me a check even though I paid cash for the part.
Moral of the story is to make sure you check the cheap easy to replace solutions before buying the expensive parts for replacement cuz you might not need them
