massacre
- January 24, 2018
- Massachusetts
- ‘94 Explorer
‘19 Nautilus
So I installed new pushrods on Monday. Some of the old ones some had worn footballed ends. I had some annoying top end chatter and thought I had a bent pushrod. One pushrod was def worn/slightly bent but most of them were straight.
The new pushrods helped the noise quite a bit but it is still slightly there. Sounds kind of like a sewing machine, I think I should replace the rockers and shafts as that sounds like where the noise is coming from. The rockers don’t seem to pivot as smoothly as I would expect.
Has anyone installed the rocker/shaft kit from delta cam? Since I already have new pushrods it would be cheaper than the full kit.
Just wondering what people think of this kit? Is this the kit where they install hardened pushrod cups into each rocker arm? I called and they said I would have to send my rockers/shafts in for them to get me the kit.
I have not replaced the lifters, they were always quiet never had any issues. They all looked great when I had the heads off. I kinda regret not replacing them while I had the heads off, but the price of them made me try to not replace them.
I didn’t replace the timing chain tensioner as it seemed ok when I had the timing cover off. But on some modular v8 engines the sewing machine noise is usually bad timing chain tensioners so maybe I should have checked that better.
Thanks for any help
Thanks for any help
