Damn mate, looks wicked!!! Merry Xmas!!!!![]()
I wish this offer was before I worked on my Truxxx spacers. Your explorer looks really good.
Solid cast nylon tubing. Fastenal carries it for cheap. I used 3" i.d. x 5" o.d. for the front, and 4" i.d. x 6" o.d. for the rear. I was a little unsure whether it would be strong enough but these spacers don't see much shear if any...mostly just compression so I think they'll be fine.
Anyway after using my chop saw to cut the right size "slices" of nylon tube for my spacers. After I did that I drilled the holes in them for the mounting studs. I then used my tap set to tap some threads in the holes. Then since I was using new, disassembled struts, I knocked out the existing studs out of the strut tops. I installed grade 8 bolts that were longer than the original studs and threaded them through the strut top plates then through the threaded holes in the spacers, using epoxy to lock them in place. Then I tack welded the bolt heads to the underside of the strut mount plate for extra strength. The strut mount plates and springs were mounted to the struts, and that was that.
I have extra tubing left over so if anyone wants to copy this, I'll be happy to cut a set of front and rear spacers and thread them. Or I can make a set of spacers assembled to the strut tops if anyone wants those...you'd just need to assemble them to the struts.
I am very interested! how does your new setup ride?
Noticeable improvement over the old stock struts for sure. When I hit bumps I can feel the suspension reacting firmly but it doesn't create a jarring feeling in the wheel or in the seat.
Not sure how much if that is the springs vs the struts but I am happy with it.
Spacers are holding up perfectly.
As far as height, now that the springs have had some time to settle I'm sitting at 39.5" from ground to the lip at the top of the fenderwell for both front and rear.
Glad to hear your plan is working out! what was your starting height after your new struts and springs w/ spacers before they settled? were you serious about making some extra spacers? I'm still torn about what size I want but I would rather my other suspension parts not be rubbing or deteriorating faster than they should so I prob keep them smaller.
easy to picture the height in my head. thats how high mine is lolI'm sitting at 39.5" from ground to the lip at the top of the fenderwell for both front and rear.
those custom spacers look real nice james, congratulations!
i'm up in the air about what i want to do to my ex next. i want more lift, lol. so i'm sure my truck IS indeed sagging at least 1" if not more. so my options are:
should i upgrade to rancho quicklifts all around in addition to my spacers?
should i make 1/2-3/4" spacer shims?
should i buy stronger Old Man Emu springs and have them mounted on my struttek/stock struts to compensate for the sag?
