Sea Foam? | Ford Explorer Forums
Sea Foam?
jernla
Sulphur La
2000 Eddie Bauer V8
Has any of ya'll used Sea Foam I am thinking about putting it in my V8 but am a little worried. Anyone have probs?? Thanks!!! :bounce:
I used it a few days ago, no problems at all, actually got rid of the pinging I had. Use the search function on this site to search for Seafoam. Pretty easy to do, even easier if you have another person to give it gas while your doing it.
short description - it removes some of the carbon buildup that may be in the engine.
this has been discussed a few times before. try doing a search on "sea foam" here are some of the threads that popped up when i did this.
http://www.explorerforum.com/forums/showthread.php?s=&threadid=56786
http://www.explorerforum.com/forums/showthread.php?t=92752&highlight=sea+foam
http://www.explorerforum.com/forums/showthread.php?t=93520&highlight=sea+foam
http://www.explorerforum.com/forums/showthread.php?t=91323&highlight=sea+foam
Worked great for me. Be ready for the smoke, mine had white smoke for longer than I expected.
Excellent way to help with the search feature.
I just want to add to say that I never got smoke, but when I removed my intake I also discovered that I didn't do a very good job. Stopped the shuttering in my engine though. Also managed to do it by myself, but when it stalled out it had me worried.
Some good ol Iowa trick
Used to use diesel fuel for the same purpose. Pour slowly a quart down through the carb or throttle body while keeping the throttle up. Smokes like Uncle Buck's old beater, or much worse. It'd be good to do it in the woods during mosquito or blackfly season
While on a road trip, used to add a gallon of diesel to the gas tank (making it a full tank) for further internal cleaning. The difference was notable, especially if the valves had been sticky prior to the treatment.
Isn't only suposed to clean out the combustion chambers?
I guess that would make sense. :confused: Maybe I should have thought that one through.
Immediate results
I noticed a TON of white smoke, and the engine totally perked up. Rough idle which used to shake my entire truck absolutely disappeared. Some people have run two cans through, after not noticing any change from the first.....
Karl
