91 Sport 90K 94 XLT 157K
- April 20, 2011
- North Dakota
- 91 sport 90k, 94 Xlt 157k
Hello Everyone, today i decided to sea-foam my explorer.
The engine was warmed up before i started, (i had to go get tubing from the local Ace-Hardware) so when i got home i shut off the engine, popped the hood, took off the cover for the throttle linkage, took off the intake hose and removed the throttle body hose, and hooked up my length of clear hose, got my glass and filled it with 1/3 can of sea-foam, started the engine, slowly let the sea-foam get sucked into the intake, after the 1/3 cup was gone, i went to go to shut off the engine, i noticed that the check engine light was on so i just shut the engine off.
Then i put everything back on, then i waited 10 minutes. When i went to start it, it started fine, but i didnt see any smoke. As soon as i left my driveway, the engine made this ticking/knocking noise as i was heading down the street. Is that normal?! Throughout driving various speeds/ and RPM's the engine continued to tick/or knock, but it got better and then finally quit after driving for like 30 minutes. I hope it didnt bend any valves or twist any connecting rods.... what do you guys think? Is this normal after using sea-foam? Do you think it did any harm to my valves or connecting rods or pistons/rings??
