Searched and searched but nothing came up | Ford Explorer Forums - Serious Explorations
james_c17
camden, sc
97 Explorer XLT AWD
I read the tire size and lift chart thing, I saw at the bottom u could use 33x10.50 in place of a 32x11.50. I was wondering if i could do this with a 2 inch lift front and rear? btw its a 97 xlt AWD
try putting your subject in the subject line
I have never heard of anyone useing 33's on 2" of lift without a body lift
you might be able with a lot of fender trimming
haha thanks, but i mean, the tires arent as wide so they would rub as bad i dont think.
if you were to lift both ends 2 inches, it is possible for a 32 x 11.5 to fit with a minor rubbing issue, but there is a way to just bump the inside lip of the fender a bit bending it in and back a bit with a body hammer and make it work, ,
I ran 32x11.5's on a TT/ shackle lift and it rubbed the front bumper when turning.
33x10.50s on a stock rim wouldnt rub as bad as a 32x11.50 on the same rim i wouldnt think, im looking at bfg AT's they arent true 33's i had a set on a old truck i had and the measured up to like 32.7 inches.
