ozo
- April 15, 2001
- Perth Western Australia (living in Saudi)
- 96 xlt
When i select 4lo, and then try to select 4hi, sometimes it wont disengage,do you need your foot on the brake & clutch when disengaging from 4lo, when it does disengage there has been a heavy bearing noise from the front axle/tfr case, also when in 4lo and turn past 1/2 lock there is a heavy groaning noise, once a heavy bang ! when turning tight, but the vehicle seems to drive fine, these sounds are unnearving when in the middle of knowhere in the desert! HELP!!!! No thech support here at all !!!!!!!.
