- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
Clear code see how quickly it returns
Clean mas
Check for intake leak/ vacuum leak
Check bank 1 s 1 wiring to and from 02 sensor, possibly swap it with downstream sensor for testing
Monitor coolant levels for any loss
Before this shop you had a
Misfire Cylinder one which they determined was a clogged cat? They wanted to scrap the truck… Then you were running lean with lean codes, no longer crushing the truck…
And now after more work from them you are running rich, it is quite possible that they botched the injector/ intake install if they did not replace the injector seats and o rings this could be a problem dumping too much fuel
This shop is all over the place, did not fix the problem, gutted a cat (illegal) and gave it back To you running rich and charged you full price
Run away as said before they obviously do not know these engines
Clean mas
