- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
An engine should easily make a comparable amount of torque as it has cubic inches. So a 240CI 4.0 V6 could make 240lbsft maximum depending on the combination of parts, tune etc. The SOHC will have higher rpm peaks, so the torque rpm would be more like 3500+ most likely.
The positive displacement blowers should be able to make a good bit more than the CI figure, as a maximum, and at rpm's around 2500. The blower size is a big factor in that.
Blowers should be chosen in a displacement size nearer to 1/3 of the engine CI size. You can go bigger than that and end up pushing the limits of parts and IAT numbers. But much below that 1/3 point will be like the EE Explorer blower for the 302. Those are too small for anything but a 5-7psi range, before the IAT's get hot and the gains stop.
If the M90 is a 1.3 liter blower, that is right there at the 1/3 mark for a 4.0 engine. It should be able to make 240lbsft, at a reasonably low rpm. I don't know the efficiency of blowers, but the Autorotor units will make the full boost at rpm's as low as 2000rpm.
The choice of blower should be the key. Figure the cost of the whole project, and compare it to the other options.
