2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
blower pulley?
Thanks for taking the time to look that up. I read many of the questions & answers but missed that one and Ronald was a little vague when I asked him. If the measurement instructions are referring to the blower pulley then it assumes the blower has been purchased and at least positioned on top of the discharge plenum. I was hoping to find out in advance.
I've been searching the forum for the past few hours and learned that very few have documented installing the Banshee kit on an Explorer. I read thru kabukie's thread: Supercharged 02 Sport and he did not mention any hood clearance problems. However, his engine configuration is more like the Ranger (oil filler cap on passenger side) than mine (oil filler cap on driver side). On his it looks like the intake tube is higher than the blower pulley. I guess I could always revert to a smaller pulley (higher boost) rather than cut out some of the hood reinforcement.
"Q: I have a 01 Ford Explorer Sport with a 4.0 SOHC v6. Ok my question is, will this supercharger fit under the hood with out any hood modifications? (The Stock Hood) Nov-18-05
A: If you measure from the center of the pulley torward the firewall 8 inches. Then lay a straight edge across the fender with hood open. If you have 6 inches or more to the top of the lower part of the valve cover, you should have clearance to close stock hood." . . .
