2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
Gauges Installed & wired
Today I finished installing the pod dash oil pressure gauge and the wiring for it and the vacuum/boost gauge.
I used trailer type quick connects attached to wires going to the C287 instrument cluster connector for power, ground and illumination.
The power requirement for the oil pressure gauge is minimal (the boost/vacuum gauge is mechanical) and the two added lamps' current is less than the current reduced by replacing the six cluster incandescent illumination lamps with LEDs. Tomorrow I'll start the engine and check the functionality of the meters before installing the cluster. I'll have to use test clips/pins to test the illumination. I installed the red lamp covers since the gauges are in the field of view above the dash. I didn't want them to affect my night vision.
