Spark plugs
MANDY29
Kaukauna,WI
96 Ford Explorer 4.0
I'm looking to order new spark plugs for my 96 Ford Explorer 4.0 (4 door). How many spark plugs does a 96 Ford Explorer 4.0 have? I've tried to look it up online to see how many I need to buy, but I can't find the information for it anywhere. Everything that I've clicked on just leads me to sites where I can buy them, but doesn't tell me how many I have. Can someone please help me figure this out? Please and Thank you in advance.
Join the Elite Explorers for $20.
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
1998Exp
Seattle WA
98 Limited V8 AWD
It's 6-cylinder engine, so six plugs. Not to condescend, but something tells me that if you don't know how many plugs your engine needs, the job may be a bit too big for you. Perhaps enlisting some help would be a good idea?
MANDY29
Kaukauna,WI
It's 6-cylinder engine, so six plugs. Not to condescend, but something tells me that if you don't know how many plugs your engine needs, the job may be a bit too big for you. Perhaps enlisting some help will be a good idea?
No it's ok I take no offense. My dad told me it was 6 but my husband told me he was wrong and it was 8. I just wanted to make sure before I bought them. You are definitely right though I will not be doing it myself. I will be have my dad's friend do it (he's a mechanic). He told me all I had to do was buy the parts and he'd put them in for me. I just didn't want to spend more money than I had to so I thought it was a good idea to ask.
MANDY29
Kaukauna,WI
Thank you though for answering my question.
MrQ
Smokey the Clutch is, Missed Shift You Did
Moderator Emeritus
Location
Humid, Damp, and Hot
Houston, TX
'98 EB, '93 Limited
You need motorcraft or autolite fine wire platinums. Don't use anything else.
albator
Bonny Doon, CA
1999 Mercury Mountaineer
For the 4.0L SOHC engine, the part number is
AGSF-22F-M
You can buy them from many places, for example RockAuto, or a Ford dealer. I like this dealer, their prices are very good:
Please double check wether you have the "OHV" or "SOHC" engine.
It's probably written on a big plastic piece in the middle of the engine.
albator
Bonny Doon, CA
The same plug can have different model numbers. For example, "Motorcraft SP500" is the same plug.
MrQ
Moderator Emeritus
Location
Houston, TX
'98 EB, '93 Limited
Doesn't matter really, the SOHC and the OHV use the same plugs.
albator
Bonny Doon, CA
Great! Thanks for the clarification, it will make Mandy's job easier!
Is there a thread advising how to access the plugs? It seems quite cramped in there.
MrQ
Moderator Emeritus
Location
Houston, TX
'98 EB, '93 Limited
Biggest pains are the passenger side and the worst is cylinder 3 next to the air box. You can go in from top or bottom. Through the fender well is easier, just crank the wheel all the way to the left to get in there. Make sure you use antisieze on the plugs. Don't overtorque, I generally go 1/4-1/2 turn past finger tight.
