austinmob
- July 8, 2008
- Sydney
- 96 XLT
Need some help on this one. I have a 96 Explorer.
After i did some off roading (nothng too serious), i developed a steering shake when turning. I was given the advice to replace the power steering pump so i did. The pump was definately stuffed. The shaft had movement and the pump had been making all the wrong noises for a while.
Ordered a reco pump form the US and is now fitted by mechaninc.
The steering shake is still present. The pump has been bled and there are no leaks at the pump, lines or rack.
One thing i did notice was at very low speed when turning the steering wheel a clunking noise was coming from the front end.
Could it be the CV joints. Are they the problem that caused the shake in the first place.
Has anyone got any advice or experienced anything like this.
I still get told by two different sources (mechanical) that the steering must have an air lock in it after the pump change and it should come good.
The problem with this advice is it was there before the pump was changed.
