- June 16, 2003
- Humboldt, KS
- 2000 Mounty
I changed my sloppy plastic steering intermediate shaft in my '98 AWD Mountaineer, with an all solid steel one off a '96.
The install was easy enough, just had to remove a little off the firewall end of shaft ( 1/8") so the bolt hole would line up.
Now the question.
The different shaft has caused my steering wheel to be about 1/32- 1/16 turn from being centered. Front alignment is fine, doesn't pull.
The steering box end of the shaft cannot be rotated, it slides down onto a triangular shaft on the steering box, so it only goes on one way.
Is there a way to adjust this, it kind of bugs me.
The only thing I can think of is to turn Tie rod adjusters 1/2 turn out on driver 1/2 turn in on passenger until it straightens out.
There has to be a better way?
Now the question.
