- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
The RABS on my 88 BII would activate and had the truck sideways alot of the time,just on wet roads? Without the RABS I never had an issue. Rabs was easy to byoass and delete as its just the rear brake line
My 96 Explorer the 4WABS would pulse the pedal so hard and on gravel it seemed to increase my stopping distances
My wifes 07 FJ Cruiser the 4WABS seemed to activate late, again seemed to increase stopping distances on gravel. Some research online shows we were not the only ones who noticed this on the Toyotas they had a recall to reprogram the abs software
Lots of gravel on the roads when you live where it snows
I have deleted the ABS system from these vehicles and never had an issue after
I think I dislike ABS brakes on lifted trucks period, call me old school...I learned how to drive in the snow since I was 15 and am an avid off roader, I like to pump my own brakes
Also the 4 wabs pumps can be a pita, if you leave a brake system disconnected or have a large leak and you get air in the abs pump you have to go to a dealer to have it bled? No thanks...I would rather disable it, or delete the pump/system completely.
There is about 20# of ABS pump and the plumbing that goes with it as well as the additional room you get in the engine bay on these gen II explorers.
Its just a pita to delete. You have to source some fittings and double flare some of the factory metal brake lines as well as add a T to the front brake line, but then you can be ABS pump free on your 95-01 RBV
