LBoy
- June 7, 2004
- NY
- 1997 Mountaineer AWD
Well,first off I'll be replacing my stock fog lights with a set of driving lights with 100 watt bulbs. The relay will be triggered by the high beam lead of headlights,but I also want to retain manual on/off control with a switch.
Can I run the relay ground through the stock fog lamp switch? I'd rather use the stock switch instead of mounting a new one. I figured asking here would be easier than pulling the dash apart again.
Also,I have a set of 55/100 watt 9007's sitting here that I never installed in my Mustang. I am assuming that to use them I would need to wire a relay for the high beam? I know the stock wiring and switch in the Stang cannot handle the 100 watt high beams,so I will assume the Mountaineer is the same deal?
Thansk for any info.
