- December 22, 2021
- Los Angeles, CA
- 1998 XLT 4x4
24 Rngr 4x4
coolant has a higher density than air, so it will find the lowest point possible (providing it doesnt have to flow up), thus displacing the air that was previously there and taking the space up, and the air will come out of the fill. similairly to if you fill a cup halfway with water and drop... say... a bolt in, the bolt sinks to the bottom, the water level rises, and some of the air at the top of the cup is now displaced and is no longer in the cup. the change in that is the vol of the bolt. if you put 100ml of coolant, 100ml worth of air will leave. and imo even if it aint the main culprit of this leak, its still a leak/crack, which imo i would change, is there a PYP near you? i forgot hwo much mine charged for a rad, but it wasnt bad. just flush it out
