Explorer93RDB
- February 22, 2007
- Lakeland Florida
- 92 Explorer EB 4X4
The Explorer was running like a Champ 92 EB, 4X4 Auto. stopped at store and came back in about 30 min. It always cranked with in 6 Sec. or less it started fine I pulled up to the exit and it sounded like it was running on 2 cylinders.. then shut down and only sputtered a coulple time then only would Spin. I checked the fuel pump Fuse and other fuses Nothing poored gas into intake tube it cranked. and shut down but, I had just put in 10 gal of gas then i thought Fuel pump .. ? Finally noticed that with the switch in the Run position that the only light that came on was the Battery light and the gauges worked. No CEL or Seatbelt light or any thing else..Head lights , turn signals and wipers worked fine.So it's either the fuel pump or the fuel Injector's. I hope You all may have a simple fix. couldn't find the red button under the dash. to make sure the fuel pump switch was not turned off. Thanks for any Help !:roll:
