Passenger front window will not roll up, only down. It's the same thing with both switches. I checked the voltage going to the motor and it read 5V in the up position and 14V in the down position (car running) If I put full voltage to the motor from an alternate source the window rolls up fine so the motor is good. Here is the strange part. I took out the switch and checked the voltage to the switch, it's fine. So I took some wire and jumped the contacts in the switch receptacle, the window rolled up and down as it should. So naturally I assumed the switch was bad, so I bought a new one and the problem is still there. Why is there only 4-5V coming out of the switch in the up position? The wires to the switch have full voltage and the wires going to the motor from the switch have to be good because I jumped the switch and it worked. I'm stumped. Thanks!
