TTG
- April 14, 2005
- Florida Gulf Coast University, Fort Myers, Florida
- '95 Sport
It's that time again... Now that I have my amp I need to get my new box built and be ready for the second sub. I'm using rocket's basic design found here as a base, but need to do some alterations to it due to my needs.
Firstly, it's for 2 12s, not a 15. His is a somewhat more complicated setup in that the main portion of it is a "mask", and the actual box is just a little box inside of it. Unfortunately, I need more airspace for my 2 subs so they can be ported. Outside of that, I'm not putting in the neon holes, and I'm gonna be painting it.
My plan as of now is to make an exact mold of the wheel well spaces by taping them off then fiberglassing them. These pieces will then be affixed to the box, which will have just simple easy 90degree cuts in place.
The whole box is going to be primered a few times, then sanded, then painted. I don't want a suber glossy black, so I'll probably just go with-semi gloss to match the rest of the colors int he truck more. All the joints on the inside are going to be fiberglassed sealed.
So the main questions I have for the gurus, would it be better to go with a slot port, or a circular port, and how do I tune it? The bandpass box I have now gets horrible air noises.
And how off will having 1 new sub and 1 slightly used sub be? I've heard that since they're broken in to different levels they will sound awful, but wasn't sure.
Also, I plan on putting a piece in the middle to seal them off from each other. Is this a good idea, worth it, or a horrible idea?
