akcrogers
- April 19, 2002
- Fairbanks, Alaska
- '92 Explorer 4WD 4DR XL
Finished my Superlift SOA last night. It started raining as I finished it up, so I don't have the 'after' pics yet, but I'll post pictures later this afternoon. My front lift should get here today, then I'll order any missing parts (know I need shocks and pitman arm) and I will hopefully be installing the lift over 4th of july weekend, and then the additional parts will go on early next week.
The SOA is a pretty easy and quick job, especially if you wd-40 all of the bolts several times in advance. the couple that I didn't hit with the wd were a real pain to get out. Almost all of the bolts on the back of the X are 18mm, so you only need a couple of sockets. I disconnected the parking brake, but because I was pulling the leafs instead of rolling the axle out of the way, I didn't disconnect the brake line or sensor (don't have my extended brake line yet and don't feel like bleeding the brakes twice). I knew that I wanted to swap the leafs while I was at it, so I jacked the back up high enough and pulled the leafs. Then cleaned out all of the dirt from inside the stock spring perch where the superlift bracket sits.
Side note- I don't know how anyone could think that the superlift bracket could slide, I see no reason to weld it on. Its bottom edges sit inside the lip on the stock spring perch that is welded to the axle. Once the u-bolts are on, for the superlift bracket to shift, the stock perch would have to break.
Anyways, marked the leafs left and right, and then swapped them. Put the superlift brackets in and set the leafs on top and then fought with the u-bolts for a while. I cut the stock shock ears off with a sawzall and those went on top to hold the ubolts. Torqued everything down. Then installed the new swaybar extensions, which fit fine, even around a non-stock exhaust. Finally, pounded the shocks back into place, which is going to be a pain to undo when I get the new shocks, but oh well.
Pictures tonight or whenever it stops raining. thanks to everyone who did this before me and posted info about it. It really makes a big difference going into something like this, and really knowing what you are doing. Well, time to get back to work on those rivets with the grinder
Oh, and there will be no problem with 35s on this beast. I mean, except for the $ problem...
