suspension lift questions please help | Ford Explorer Forums
maimthegod
Germantown, Wisconsin
'96 XLT AWD 5.0
right now my X is sitting very stock. id like to raise i but im am not sure on what lift to buy. i like to clear 33-35's and keep it streetable. if anyone can help me with what to buy with links to websites or anything. thanks
33s will fit with a 4" lift. There is Trail Master, Superlift, Rough Country, James Duff etc...
35s will fit with a 5.5" - 6" lift (may need minor trimming in the front). There is Superlift, Skyjacker or a combo of a 4" with a 2" or 3" body lift.
You can also mix and match f-150 coil seats and shackles in there to make it work.
Search the site on all of this stuff I just mentioned, as there is a ton of info. Good luck and welcome to the site. :thumbsup:
thanks alot ill check around the site
Also research your axle code for your stock gearing. If it's anything below 3.73's you will not like street driving with 33's or 35's.
im not exactly sure how to research it. i have a 92 X 5spd where would i go to get the info?
Door label under axle code. Then search what code it says there's a chart on what the code means.
With a 5 speed he probably wouldnt mind 3.55's or lower.
