Swapping '94 Ranger 4.0 into a '98 Explorer | Ford Explorer Forums
dgratz
Pittsburgh
97 explorer 4.0 SOHC
I have a Explorer Sport with the 4.0 SOHC with bad timing chain cassettes. I am going to replace the engine with a 4.0 that is in a '94 Ranger. Is their any known problems before I get into this?
Thanks in advance
Don Gratz
The Ranger would be a OHV motor wouldn't it?
Might be a royal pain if you in an area that doesn't emissions testing (and how they do it)
I believe it is a OHV. I think the manifold needs to be changed. Was wondering if there are wiring harnesses or ECM's that need to be changed also.
I have a 8 bolt flywheel also.
The Ranger is probably a six bolt flywheel. It's also OBD-I, and the Ex is OBD-II, so you may have some wiring/ sensor issues.
