- October 6, 2008
- Location
- Va
- chesapeake virginia
- '96 xlt 4x4
Ok was thinKing about modifying the replacement end links I just put in so I can disconnect the front sway bar without tools and also replacing bolts with hitch pins on the rear sway bar to disconnect it as well the front sway bar I'll disconnect for off-road use only, to smooth out my ride on the beach and get more articulation on the mountain trails, the rear sway bar I'll probably only disconnect for the slow paced technical trails along with the front. ...... so basically I have two questions ......#1 is the offroad performance gain worth the hassle and #2 what do you with the sway bars when there disconnected ? Install hangers? I have seen lots of pictures but none with hangers or a solution to secure the loose sway bar!
