tbars has the Aussie in the front (ttb) and the stock LS in the rear and his radius is bigger than mine. IZ remembers that from the Truck Haven ditches. I have Detroit in the rear and Tru-Trac LS up front.
I do remember that -- everytime FROADER was leading and took a sharp turn, a middle finger came out of TBARS' window.tbars has the Aussie in the front (ttb) and the stock LS in the rear and his radius is bigger than mine. IZ remembers that from the Truck Haven ditches. I have Detroit in the rear and Tru-Trac LS up front.
I have no problems with my LS. Cj Hill at Truck Haven, the Rubicon twice and Moab twice is proof of that.I have problems with LS's though, they're there untill you really need them. Thought about spooling the rear and doing an LS up front but since it's still city driven i know my tire wear would go out the window.
And that difficult dinosaur poop in the Thanksgiving run.I have no problems with my LS. Cj Hill at Truck Haven..
I have no experience, but I've heard the stock trac-loc LS is a POS.![]()
Well if you have an LS rear, you have to change the carrier to an open unit before you can slide in an Aussie as the Aussie is not available for the 8.8 LS. I'm not 100% sure of the LockRight but the NoSlip however is available for the LS carrier (but a bit more $$). But you can find 8.8 open carriers in junk yards all the time -- you just have to play around with the carrier shims a bit to make sure the gear contact pattern is within spec after the carrier swap.
...after i fixed my rotor problem my turning radius is better offroad as the aussie isn't constantly engaging...
...if your vehicle is not going to be totally offroad i myself would put a selectable locker up front and an aussie in the rear...just my .02..![]()
