- June 24, 2003
- Newcastle Wa
- White 94 Limited
- Callsign
- KG7PKQ
How?
Is there not a square hole there somewhere on the bracket that you use to compress the spring and release the tension for belt removal replacement?
Perhaps you can't do it while the engine is running.
Interesting that a short belt made the tick go away for a week but now when the belt is broken in the tick is back.
I thought you said the tick was NOT RPM dependant. If it's the belt or any of the rotating parts assiciated with it, the tick should be.
How smooth are the seams on the belts you've tried?
I'm doin my best to try to help but if I'm not helping, I'm out.
