How to: - Timing chain rattle resolution process - SOHC V6 | Page 5 | Ford Explorer Forums
How to: Timing chain rattle resolution process - SOHC V6
Prefix for threads which are instructional.
Hi! Hope this finds you well amidst this pandemic! Quick question, the rattle is quieter when cold started but louder as it gets warmer and loudest at 2500-3500 rpms... any thoughts? thanks so much!
I would suspect the primary chain tensioner has failed or the balance shaft chain tensioner if you have one.
thanks! it has both! i suspect t occurred when i started it and had to give it a little gas... reveled to 2.5k on startup... thanks! hoping i can get to it during the summer months... also hoping it the primary tensioner since it is still on the factory 3 leaf design...
