- February 3, 2007
- Oakland, CA
- '00 Mountaineer
2 things...
1) I would rethink the way you attached the lower end of the limit strap. Especially with that 1" (approx) spacer you have between the tab and the arm. It may hold up like that, but I can see something bending or breaking in a high-tension situation. Weld a vertical tab onto the lower arm for the limit strap.
2) What's the extended and collapsed length of those shocks, from eye to eye? Just curious because those look way shorter than the 12" shocks i'm used to seeing.
