og
- May 3, 2005
- Northwest Indiana
- 98 xlt
OK for the diagnosticians on the board, here's a real stumper.
1998 Explorer XLT. 5.0 liter v8. Increasing driveability issues between 11/29 and 12/3 288,000 miles.
Took to dealer for diagnosis. Dealer claimed it was a clogged cats, claimed it improved when the O2 sensors were removed. Dealer wanted $3500 for new cats.
Took to local muffler shop I trust, who replaced the system, headpipes back. (for $1500)
No improvement in driveability. In fact, somewhat worse. Turning substantially worse by the time it got home. (two miles)
Pulled into the driveway and parked to discover the passenger side exhaust manifold glowing red.
Have had a small crack in the original EGR pipe. Thought that might be the source of the trouble, so I replaced. While I was at it, I removed the intake upper(you almost have to) and replaced gaskets, in case there were any vacuum leaks due to old or perished gaskets.
No improvement.
In October- for the very first time- I let it run out of gas. I thought, maybe I sucked up some gunk from the tank, and clogged the injectors.
I pulled the fuel rail and injectors, built a test stand, and flow tested the injectors. Used Techron and alcohol to clean, the fuel patternis nice and the injectors all seem to be clean. Reassembled (again!) and no change.
Used an old, properly gapped spark plug, clamped to the block, and confirmed i have spark. No idea of the spark is occurring at the proper time.
Injectors tick, so I assume they're injecting. Noid light test shows flash at all eight injectors
THe fuel pump did bleed down somewhat, so I replaced the pump. still will not start. Pressure stays up, apply vacuum to the regulator, and pressure drops.
Changed the Camshaft position sensor. No change.
THe ECU threw no codes. Still throws no codes.
TPS, MAF sensors all seem to be fine.
Any clues, folks? I'm utterly stumped. I LOVE my exploder, and want to keep driving her another 100,000 miles at least.
I have changed out damned near everything but the ECU, and that's probably next- but dang.
New plugs
New wires
New coil packs
New Camshaft position sensor
New EGR riser tube
New fuel pump
New fuel filter
New exhaust system
HELP!!!!!!!!!!!
No improvement.
New plugs
New wires
New coil packs
New EGR riser tube
New fuel pump
New fuel filter
New exhaust system
HELP!!!!!!!!!!!
