Transfer case mods | Ford Explorer Forums
Transfer case mods
ammo troop
Perry County Ahia (Ohio)
1993 "BAD"Sport"
Hey folks, Need some gearheaded brainstorming, Convinced myself to modifying my transfer case from the present pushbutton type to cable actuated. The plan is to use a generic twist lock cable set up available anywhere and have a piece machined that will bolt on over the transfer case actuator ( the triangle ) and run it up thru to the dash. Question: Has anyone else tried this,If so any advice? What bearing will it have on any other electrical component? Such as speed sensor. ANY help???
I was considering dooing the same thing with mine, only I was going to ues a marine grade push/pull cable assembly and a throttle control from a boat to control it. I don't belive it will affect the electronics, but you must keep the plate that covers the speed sensor from comming out and reinstall it.
