- February 2, 2002
- 1998 Mountaineer AWD
Shouldn’t be any bends in the shaft.
what do you mean bend? they aint supposed to bend...The trouble is finding one with the correct bend in it to get past the torsion bar key
oh, whoopsI think it was a joke, the 1356 is too big and the shaft would hit the torsion bar frame parts. That's how I took it to mean.
That's whatShouldn’t be any bends in the shaft.
im so glad you added that to the quoteThat's what
-She
Whats the size difference between the 2?I think the 242 is a better unit. The part time 4 wheel drive torque rating is identical to the 231 and would allow fulltime 4 wheel drive. In my jeep, I use the fulltime in heavy rain, on ice or hauling ass on a winding road with sharp curves.
I have 1 still attached to a transmission. I could rough measure it.Whats the size difference between the 2?
Righ now I am searching for the measurement of the distance between the input and front out put. Any chance you have a case to measure?
OkI have 1 still attached to a transmission. I could rough measure it.
^^^^^dont try to reinvent the wheelWhy not just use the same t case that has been used in dozens of swaps and proven? Trying new things will invariably bring headaches, like the case you have being too large. The 4406 is a guaranteed fit.
There is no guarentee the 4406 will fit either. I am using a mustang 3.8 v6 with a toploader. The motor and trans sit 5” lower than a stock explorer setup.Why not just use the same t case that has been used in dozens of swaps and proven? Trying new things will invariably bring headaches, like the case you have being too large. The 4406 is a guaranteed fit.
Oh, well that changes everything. You’ve already opened the can of worms. Proceed wildly, and take lots of pics.There is no guarentee the 4406 will fit either. I am using a mustang 3.8 v6 with a toploader. The motor and trans sit 5” lower than a stock explorer setup.
Thank for the infoSwapping in a 242 would be easy. Change the input shaft on the transfer case to a 31 spline and bolt it up. Novak makes a nice shifter.
