Note: This feature currently requires accessing the site using the built-in Safari browser.
Performance Upgrades - Maintenance - Modifications - Problem Solving. Covering the Explorer, ST, Lincoln Aviator, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Mazda Pickups, and the Aerostar.
Finally ford company realized that they couldn't make a good solenoids, so now the new solenoids come from Germany with ford sticker....
I'd clear the KAM, which would force it to relearn everything, but does the valve body have to be flashed into the PCM for it to even work? I know some of the components require the PCM to be flashed for them to even operate.
You can replace just the valve body without reprogramming the PCM if you swap the old TCM onto the new valve body. The rebuilt Mechatronic assemblies come without the TCM.
The original TCM is programmed with the PCM already.
That's exactly what I was thinking and wanted to know! For $300 and a few hours of my labor I might have to try this and see if it fixes a few of my minor issues.
Has anybody solved this problem? A have same jerking on the 1st gear it traffic jam on my 09 Explorer with 6r80, sometimes when you touch the gas while moving 3-4 mph the car jumps forward very hard, annoys very much
First thing I would check is the fluid level to make sure this isn't an issue. How many miles are on you Explorer and when is the last time the transmission was serviced? Have you done any software updates?
