Transmission swap ideas? | Page 2 | Ford Explorer Forums
May be a bit more if it’s 4x4. T case spline counts, drive shaft lengths. Just the first things that come to mind.
The tools to rebuild most automatics are expensive these days. What used to be $100-$150 for tools, I think will run more like $300 or more for sure. So to attempt a rebuild yourself, you need to be prepared for the cost of several special tools.
If there is no extensive internal damage, the parts besides the clutches/seals, then a rebuild is not a huge deal for anyone mechanically skilled. It is tedious and takes good patience to be sure that nothing is misplaced, mixed up, and all is put back exactly as intended. A basic $15 manual can cover almost everything you would have to know, and that is the absolute must have first thing to buy, and read.
Parts can be as little as $150, but a torque converter and replacing all solenoids, accumulators, and other broken or damaged parts, are most of a rebuild cost, not counting labor. Shops make their profit on the R&R of the trans, not the actual rebuild. Their high cost is partly to cover come backs, which can be many and expensive to them.
Be sure to install a new external filter in the cooler lines. That can be a simple inline filter placed in the return line(not the output line).
if you can do a cheap 6r80 that would be your best bet
The 6R80 would be the best upgrade, but the swap would be a big deal regardless of the price. I wish Ford would stop changing bell housing patterns, I'd love to think if swapping a five or six speed trans in.
