Ronin8002
- March 23, 2003
- Virginia
- 2008 XLT Ironman
This probably sounds pretty funny to most people here since most people remove a 2wd axle to put on a 4wd, but I want to ditch my 4x4 axle and transfer case and go 2wd. No, I don't want to simply buy a 2wd explorer, I just want to see what I might be getting into.
Anyway, I just want to know if it's as simple as getting a junkyard 2wd front end and swapping it out with my 4wd axle or if there are any surprises or "gotchas" that I might have to deal with.
Also, the output shaft on my trans, obviously it was designed to fit into the transfer case...however can I use the driveshaft from a 2wd explorer and have it hook right up or am I looking at getting something custom made or modifying the stock part?
Lastly, I know that the speedo cable feeds into the transfer case....if I ditch the transfer case obviously I need to hook it up somewhere else....any ideas on that?
Lots of questions and I admit I didn't do a ton of searching but hopefully someone will have some insight on this. Thanks in advance!
James
James
