turboexplorer
- August 23, 2008
- Eagle Mountain, UT
- 98' XLT 5.0L 4X4
- Callsign
- Turbo
Getting the leafs set into place. The hole for the pin on the spring perch was a hair under 5/8" so I had to run to ACE and pick up a 5/8" drill bit so I could get them to fit the locating pin perfectly with no pressure or any play at all.
Used ratchet straps to hold axle up to the leafs. Cheesy but worked really well. The straps had enough traction so the axle wouldn't try and roll all all when being lifted.
My rear shocks look sad, they have seen some weather over the last few years and 7,000 miles.
So I tried a cleaning tip that FOX told me to do on my coilovers to keep them clean on these and it really did do a good job, if I would have done it sooner or once a year I probably wouldn't have the spots that are still there. The tip was to use a scotch bright pad and WD40. Spray them down and rub with the scotch bright pad. Rub only in the direction of the grains of the aluminum. If you go across the grain you will see scratches. But hey you decide here is the before and afters. (Now to do my coilovers, haven't had them out since I called FOX about the finish. Dang road salt)
After it is sitting on its own again.
