I decided a couple weeks ago to purchase LED brake lights and turn lights for my truck. I purchased a LED flasher unit too so my turn signals don't flash really fast.
It was a pain getting the flasher unit in, but I finally got it in. I put the bulbs in easily, and then tested my light. Everything looked great.
I left home, headed to work. When I got behind a car, and used my turn signal, I thought I saw my fog lights on. I thought that was weird, so I pulled over and checked it again. It was fine. I got back on the highway, and as I merged, I was behind a pick-up truck. I had my turn signal on, and my fog lights were flashing with my turn signal!
After I got to work, I tried to show my co-worker who knows a lot about cars. It wouldn't do it. But, when I turned on my hazard lights while in park, it started flashing my fog lights again.
Does anyone have any idea of what might have happened?
I have an '04 Explorer Limited. I have Auto-Lamps. This ONLY happens when I have the switch on Auto, my fog light switch on, it's light out (so my fog/headlights are not on), and I'm driving.
If I'm stopped, it all works as normal. If my fog light switch is off, it all works normal. If my highlights and fog lights are on (automatically or manually), it all works fine. Anytime my fog lights are in the "off" position, it works fine (regardless if my headlights are on or not).
I'm kinda puzzled since I didn't make any changes to the wiring. The only thing I did was put in the LED flasher unit (from www.superbrightleds.com) and put in LED's (from www.ledlight.com).
Does anyone have any experience with this, or have any idea's for a solution?
Another thing to throw in the mix too...I have a Viper Remote Start connected. When I start my truck, or unlock/lock the doors with my Viper remote, it flasher the parking lights (the dash lights light up, my parking lights light up, and if my fog light switch is on, the fog lights will light up too). So I don't know if that's screwing it up...
Thanks for your help!
