What is The TPS Adjustment Mod? | Ford Explorer Forums
Big_Stig352
Spring Hill, FL
93 Explorer Limited
i read about it in an old old old thread and i cant find anything else on it, ive looked everywhere..
Also note that a TPS has a wide margin of working voltage & may react differently on your X. Higher may run better lower may run better & anywhere in between. Just because you can get it to the voltage indicated doesn't mean you will see any benefit. In fact like on my X you may see intermittent check engine lights indicating code 23 "TPS voltage out of range"
