What is this part? | Ford Explorer Forums
What is this part?
BTR
MARIETTA, GA
2000 XLT 4.0 SOHC 4DR 2WD
2000 Explorer XLT 4DR 2WD. 4.0L SOHC JOB 1 (VIN E). 5-Speed Automatic O/D 5R55E. 158,000 miles.
There's a round, plastic ball on top of the front right fender liner. It's about the size of a softball and it has 2 extremely small hoses connected to it. I broke one of the hoses. What is the ball... what does it do... what system is it a part of? Please advise. Many thanks.
I don't know for sure, but I would guess it is a vacuum ball possibly for the HVAC system or emissions.
Vacuum res
Its the vacuum reservoir. Dorman offers
replacement
This thread will help .
Is the hose break clean, in only one spot and not a significant length missing?
If so then I'd consider getting a hose coupler, for example here is a kit, and I don't know the diameter needed to just get one of them:
Otherwise I'm sure there's forum topics here describing where they go, like to the firewall for the HVAC, and you can replace a hose with bulk vac tubing sold by the foot at auto parts stores, or just add a segment of new hose and two couplers where the broken area is.
Depending on the diameter, even a piece of rubber fuel line hose might work, though if your existing tubing is brittle, it might take finesse to get both ends into a coupler with an air-tight fit. Replacement of the entire (old, brittle) hose would be the safest bet, and most labor.
