What oil is in your rig? | Page 5 | Ford Explorer Forums
What oil do you use?
  • 10W30
    Votes: 102 24.1%
  • 10W40
    Votes: 35 8.3%
  • Straight W-.....
    Votes: 5 1.2%
  • 5W30
    Votes: 140 33.0%
  • 5W50 synthetic
    Votes: 54 12.7%
  • 10w30 synthetic
    Votes: 88 20.8%
  • Total voters
    424
Better gas mileage... of course;)
I used to.....
Originally posted by AlaskanJack
Just switched over to Synthetic fluids all around!
I'm using all 5W30 ROYAL PURPLE. Anyone else use Royal Purple?
but that's not a full synthetic {unless you go to the race line $$$$}
I went to Amsoil and never looked back.
For some reason I just got my e-mail notification today that there was activity on this thread...
Anyway in respone to Aldive, Rick is partly correct. I use 5w30 because of the manufacturer recommedation, but only a few qts because it just seams to be too light (hey I grew up on 10w40). If I had to choose one then it would be 10w30 all the time. The Winter sees more of the 5 because it flows faster than 10 at cold start ups and that is were most engine wear occurs. (Not everyone has a block heater like AlaskanJack).
I've been lucky in that I have found Mobil 1 in a 5qt jug for $19...
Re: I used to.....
It's not full synthetic!!! Man at the prices I paid for this stuff, it better be. I am paying like $8 qt for the motor oil, tranny fluid, power steering fluid and then $12 something for the 16 oz bottle of purple ice for coolant. Heck I bought a 5 gallon container of the gear oil and paid $117 for it.
Re: Re: I used to.....
thats the info I got from the place I was getting it from....WWW.Hiperfuels.com in fact, I still have a full case oif it with the hiperfuels stickers on the bottles.
I wanted to get extended drain intervals,and NEEDED to know that my oil was indeed a full synthetic.
I was told that the Race lineup of oils were full synthetics,but the prices were through the roof ?
edit below........
I just went to the hiperfuels site and they now list these oils as full synthetics ???
I would try to get intouch with Royal Purple and find out about this if I was you,if your changing oil every 5-7 k,it won't be a problem at all.
I had Royal Purple call me back !
I was curious..what can I say ?
spoke with someone that was nice enough to stay on the phone even though I told him off the bat I'm an Amsoil customer/dealer{a dealer only to get it for myself at cost}
what he said is this oil goes along way with a bypass setup {standard full flow and a bypass type filter}
he's running it on his Dodge truck right now.
this isn't a full synthetic oil,since the additives come in a mineral base.
However,they may be one of the few that mentions the additives coming in a mineral base package.
Amsoil or RP.....you can't go wrong either way,
but I'm pro Amsoil !
Originally posted by Rick
Oil... you mean there is supposed to be oil in my rig :D
Yes Rick, there is supposed to be oil in your rig. Unless you'd rather have your engine seize. Ha Ha
Will
Saw the pics. I like. Like the tranny temp guage and tranny filter. I want one. Hey that Amsoil SDF57, ¿Isn't that the one that Amsoil calls for on our engines? Been a while since I changed mine so I dont remember. ¿How did you hook that thing up?
Nic :, that Amsoil SDF-15 is the full size engine oil filter.
I use that and a bypass {BP-100} in a dual remote bypass filter setup.
the Amsoil SDF-57,is a smaller filter that I needed for clearance issues where my remote tranny filter is located.
On the remote mount for the tranny filter is a place to add the sensor that you would also buy when you order a gauge,gauge housing {pod}then just wire it up !!
I swap between a mix of that valvoline highmileage and quakerstate 4x4 or just amsoil it all depends on the size of my wallet at the time.
just switched to 5w30 synthetic about a month ago and i love it....great stuff...Mobile 1 all the way...:D
5-30 penzoil
Mobil 1 5w-20
motomaster!!!!
Dont know what motomaster is do you??? Dont have Canadian Tire stores do you??? Well :p
