What would you save or do? Saving parts from a 1991?
natenkiki2004
Blue Bomb!
Location
North Idaho
1991 & 1994 Explorers
Both my 1994 and 1991 Explorers are not able to drive on the road. The 1994 is relegated to farm duty since it still runs but has transmission issues that mean only 1st and reverse work. My beloved 1991 failed me this summer (trans pan dumped fluid) and has been sitting in shame since.
The 1991 has 246k on the clock, engine ticking, occasionally runs rough, oil leaks, requires premium gas, has a leaky windshield and rear windows, has the steering box leaking, has no AC, no ABS, speakers are blown out and I'm sure other things I've repressed in my memory.
The 1994 is not in horrible shape. Engine has 190K on it and is silent and smooth, it has ABS, premium sound system, no real leaks (minor radiator), doesn't care what gas I give it or how long the gas has sat in the tank, power windows and while the AC doesn't work, I could possibly retrofit. The major downside is the trans not wanting to come out of 1st. I've done a TON of diagnosis on this and haven't made any progress aside from being pretty sure that the valve body is clogged up with crud. I've checked all the brakes, repacked the front wheel bearings, replaced brake hoses, done radius arm bushings, exchanged all fluids and gotten it usable as a farm rig.
My thoughts are to bail on the 1991 and see if swapping the valve body fixes the 1994. If not, I might think about swapping transmissions but I don't like that so much. But, if it does work... game on.
My question for all of you is would you do this? If so, what would you save from the 1991? I may not have a long-term place to store the 1991 for parts so it might have to get sent to the junkyard after I scavenge.
My short list of parts off the top of my head would be:
Valuable electronics like the computer and sensors
Whole rear axle (the 1991 has limited slip and I rebuilt the brakes less than a year ago)
Tires & wheels
Front Axles (thinking of lifting and making the 1994 a mild offroader)
Transmission (while the 1991 leaks, having it out means I can attempt to fix, it is worthwhile as it was rebuilt professionally)
Seats (they're from a newer Ranger
Any ideas or thoughts on parts or my plan of attack here?
T UPDATE. Removing clutch to save truck from dump. Stock 1991 - 1994 Explorers 6
T Last chance to save my explorer or the girlfriend is taking it to the dump. Clutch problem. Stock 1991 - 1994 Explorers 19
9 serious help need... search cant save me now Stock 1991 - 1994 Explorers 32
D How to save your transmission? Stock 1991 - 1994 Explorers 11
C Project Life Saving Explorer Stock 1991 - 1994 Explorers 6
C Need help with a 1994 Explorer parking brake parts Stock 1991 - 1994 Explorers 4
T Where to find Parts Stock 1991 - 1994 Explorers 3
K Which models parts will fit my 1994 Explorer sport? Manual Transmission! Stock 1991 - 1994 Explorers 4
F Ranger / Explorer parts interchange Stock 1991 - 1994 Explorers 2
I Parting Out my '92... what are fair prices for parts? Stock 1991 - 1994 Explorers 0
T No brake lights/4-ways, also...Looking to buy new 1992 for parts, question. Stock 1991 - 1994 Explorers 3
U Interchangeability of body parts? Stock 1991 - 1994 Explorers 14
catdaddy Missing some parts, Stock 1991 - 1994 Explorers 4
E Interchangeable parts help Stock 1991 - 1994 Explorers 2
9 New parts for a '91 Stock 1991 - 1994 Explorers 6
S A couple parts questions Stock 1991 - 1994 Explorers 3
T Ford Explorer Newbie Needs Advice on Parts Stock 1991 - 1994 Explorers 13
T Love throwing money at parts...and still not "right" Stock 1991 - 1994 Explorers 22
I parts truck compatibility questions Stock 1991 - 1994 Explorers 3
K 1993 Explr XLT, AT cruise control parts Stock 1991 - 1994 Explorers 4
E 1994 Ranger 4x4 front end needed. No parts to be found ?? Stock 1991 - 1994 Explorers 5
K New parts Truck won't start... I need help Stock 1991 - 1994 Explorers 35
W Essential spare parts and checks for a 4k drive Stock 1991 - 1994 Explorers 8
L.A.X Interchangeable Parts Stock 1991 - 1994 Explorers 13
S Help in identifiying parts Stock 1991 - 1994 Explorers 4
FR-425 eBay Parts search Tip Stock 1991 - 1994 Explorers 0
C replacing heads, found some worn out parts Stock 1991 - 1994 Explorers 2
L.A.X LMC EXPLORER PARTS CATALOG/Amazing Stock 1991 - 1994 Explorers 2
L.A.X Where do you get your replacement parts? Stock 1991 - 1994 Explorers 11
M 91 Ex 2wd only getting around 14mpg ... lots of new parts help !! Stock 1991 - 1994 Explorers 26
T What are the "hard to find" parts? Stock 1991 - 1994 Explorers 38
C Motor & Trans Rebuild - Need Parts Help Stock 1991 - 1994 Explorers 5
F Front hub parts identification help Stock 1991 - 1994 Explorers 0
H Need help finding parts Stock 1991 - 1994 Explorers 9
Blue91Ex Parts for my future '91 ex. Stock 1991 - 1994 Explorers 34
M Compatible parts for 1993 Explorer Stock 1991 - 1994 Explorers 5
C List of parts to replace? Stock 1991 - 1994 Explorers 8
D Scavenging for Navajo parts. Stock 1991 - 1994 Explorers 12
B Parts Needed Rear Window Fix Stock 1991 - 1994 Explorers 9
J What are the parts I need for replacing this Stock 1991 - 1994 Explorers 9
mr cribb motorcraft slave cylinder vs local parts store/ ebay Stock 1991 - 1994 Explorers 35
H How much is a 94 2x4 parts EX worth? Stock 1991 - 1994 Explorers 13
SavaX Rockauto first gen parts blowout Stock 1991 - 1994 Explorers 6
M Two questions: production numbers and finding used parts Stock 1991 - 1994 Explorers 3
E parts compatible with 94 explorer Stock 1991 - 1994 Explorers 1
S Help needed again! 4x4 parts and brakes Stock 1991 - 1994 Explorers 9
S Help needed again! 4x4 parts and brakes Stock 1991 - 1994 Explorers 0
T Cold air intake replacement parts Stock 1991 - 1994 Explorers 13
A 2000 parts on a 93 XLT? Stock 1991 - 1994 Explorers 2
S Looking for parts Stock 1991 - 1994 Explorers 5
Similar threads
